NO POWER TO A/C AND HEATER CONTROM
A home for 1983–1989 300ZX owners!
Glorywagon
Car: 1985 300ZX turbo
HI all I need help please I have a 1985 Z turbo didgal dash I have no power going to the main controls on the dash?They do not light up or anything . any suggestions? Danny
Modified by Glorywagon at 9:14 AM 4/17/2007
Modified by Glorywagon at 9:16 AM 4/17/2007
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the digital power suppy unit found under the dash to the right of the steering column
Glorywagon
The didgel dash lihts up ok and works shouldn"t the heater controls work also?Danny
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
Dash cluster and climate controls are on a seperate circuit. Have you checked all the fuses?
evildky
06 Nissan 350Z GT
Glorywagon wrote:I have no power going to the main controls on the dash?They do not light up or anything
so they do light up? it's just the climate control not working?
Glorywagon
This Car someone has removed the A/C and all the controls I have bought some used heater and A/C controls . the heater should still work even if I don't hook up an a/c unit?I havn't checked breakers yet. I'm not gonna have a/c heater only.
AZ-ZBum
Glorywagon wrote:This Car someone has removed the A/C and all the controls I have bought some used heater and A/C controls . the heater should still work even if I don't hook up an a/c unit?I havn't checked breakers yet. I'm not gonna have a/c heater only.
Therein lies your problem. You probably should have stated that in the original post. Are the new controls from an automatic or manual climate control system? Are the old controls from an automatic or manual climate control system? What do you have in place of the AC box?
The system should work without the AC system inplace, but if you don't have all the vacuum lines hooked up properly, you're SOL.
Glorywagon
I have a didgel controls. all thats missing is the condencer and the conpressor and lines. none of the main a/c and heater has been removed . Just don't have power yet. I thank I did say didgel dash at he beginning. I just don't see any use on a t top or a convertable car with air cond. If its that hot I'll just drive my van. Danny
Return to “300ZX (Z31) Forum”
