PAintballa45 »
https://forums.nicoclub.com/paintballa45-u140813.html
Mon Apr 23, 2012 3:15 pm
removing the egr with the motor in is a royal pita but it can be done by pulling the upper plenum. If your running stock manifolds you have to cap the exhaust port and upper intake with plates from a delete kit (about $30, z1 sells it along with most websites). AIV's are usless, rip all that garbage out (solenoids are in the fenders behind the front wheels). youll have to cap it before the cats if running stock pipes. You also have to cap all the vacuum lines where those systems were previously. Leaving the plugs unconnected will not throw any codes or effect the idle / performance
edit: do a power balance test (disconnect each coil pack 1 by 1. If you hear a drop in idle, the cylinder is working properly, if not, you have found the reason for running rough). very simple diagnostic test.
