no power
MoToG
Car: rb20 240sx
i have a rb20det in a 240sx ran good than some bad stuff happen with wiring idk where so i bought a wiring harness and started over.and rebuilt my head in the process because had some bent valves so i rebuilt my head got a new ecu and wiring harness i re-did my lower harness. it will not start up unless its being pulled by another car and drop the clutch and let it turn for a bit, and it will not idle after started. problems- idle, no power barely makes it threw 2 gear. things iv checked for- boost leaks i have none, getting spark, getting fuel, air, timing is perfect, i have a stock ecu and a tomie chipped, it runs a little better with the tomei chipped, im completely out of ideas help please!!!! o and no low end power what so ever almost stalls from a stop i have to burn the clutch basically
MoToG
Car: rb20 240sx
help please checked my ecu codes are temp sensor and tp so im gonna trace my tp wires but idk
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
ECU temp sensor get the 300zx one from the dealer.
