no power possible blown fuse link (big ones)
leedrm
Car: 1995 Infinti J30
ok.. I'm a dumb-a**...
I change the fuel pump, and was trying to bleed the air from the lines, when my battery went dead.
I charged the battery and f*****g arched the battery. Now nothing no power lights nothing.
I'm thinking a BIG fuse link, but not sure which one needs to be replaced, there is no way for ME to check for bad one. Tried to put flashlight next to it, but cant see if its broke.
I thank you in advance for your help..
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
its probably going to be the big 100A fuse, the 100A feeds everything..
Fuses can sometimes look OK but not test OK, test either with a meter or test light...
http://www.nicoclub.com/FSM
Check out the "power supply routing" in the front of the manual.
leedrm
thanks, I appreciate that info. I was look for the wiring diagram.
If you had quess, which one was burnt out, which one would you guess. Starter of ingition?
elwesso
2007 BMW M Coupe
hmm, i'd check both personally, its a matter of pulling the fuse out and checking continuity...
leedrm
Thanks....I will check.... I apprecaite your help..
Have a great Day!
