kyleamiller »
https://forums.nicoclub.com/kyleamiller-u207163.html
Mon Jul 23, 2012 7:59 am
I recently bought a 1990 300zx NA and it runs decent but there seems like there is no power. The previous owner did a motor swap so there are cables/vacuum lines that dont go anywhere, EGR valve deleted ect.
Things done so far:
Sparkplugs
fuel injectors
water pump
MAF
throttle postion sensor
Symptoms:
ECU is throwing the det sensor code
I tried to check the timing with an inductive type light but when I put it on the #1 coil the signal was barely there. If I disconnect the plug the engine dies. The signal on the other coils is erratic at times. When I remove the other cables one at a time the engine comes close to stalling.
Also if I turn the throttle position sensor all the way clockwise it runs ok but if i turn it all the way counterclockise then it is extremely bogged down, I cant rev past about 2k.
This is my first project car and I would really appreciate help/suggestions.
