KaZ (VaBch) »
https://forums.nicoclub.com/kaz-vabch-u11666.html
Tue Aug 03, 2004 5:56 pm
Yeah, bad gas can be a huge issue...
I've had cars buck, stall, die, won't get out of their own way... simply because of bad gas. Got 5 gallons of 93, put in a full bottle of Redline Fuel Treatment, and held the RPMs at 3-4k best I could (had to keep jabbing the throttle). After about 5-10 minutes... it finally started to idle normally... bad gas is evil... EVIL I SAY!
Oh, and you definitely need an O2 sensor if you're running the stock ECU. ECU will freak out and make you run PISS rich if there is no O2 for safety reasons (rich > lean for engine life)
