no power.... help please!
da mirakulist
Car: 87 RX-7 base model
Modified by da mirakulist at 11:35 PM 5/5/2009
slipnfall
Car: '06 D40
mir: Are you holding fluids ok? No visible leaks, loss in fluid level, or mixing of oil/coolant? What all was done to the head? Did you completely check the timing(ie the chain/cam positioning), or measure it w/a timing light?
-Jamie
silencer.1
Car: women, my car, paintball
Always check that plug wires are correctly set at
4321
I don't know how many times I've seen this problem on cars and it's usually wired wrong... Also check with a timing light. I just installed a new engine into my car this weekend and the timing was off 10 degrees right from the get go. I changed it back to normal and it runs like a champ now.
