dantesdoom wrote:Well, i mean this in no disrespect, just asking, did you check the fader and make sure that its set so that the speakers get sound. Once that's out the way, i would look at the wires as stated. You could possibly test this hooking up new wire to the unit and new speaker while its out the dash and seeing if it works. If not the units bad, any idea on how old it is BTW
None taken, fader has been adjusted - it was my first possible solution attempt a looong time ago lol. Thanks for the tips. The car was produced in '90 as a '91 and it's the stock head unit, so I can only assume it was never replaced.
NolimitZ32 wrote:What headunit are you running?
See above.
Also, my buddy and I still haven't had a chance to get this worked out. We'll take a look after Christmas break.
