180fan »
https://forums.nicoclub.com/180fan-u3602.html
Thu Aug 02, 2007 9:59 pm
checked out the clutch to see if it's still grabbing at those rpm?
if it's also surging and you've checked for vac leaks and also cleaned up the connections at the electronics (I hope this is what you meant by spraying brake clean over the wires), and done a tune up, you could also be having a situation with 1. the tps, if it's malfunctioning then the ecu would be dumping wrong amounts of fuel to deal with the air in there. 2. is there a temp dependence by any chance?
