Remove negative battery terminal. unplug the ignition switch harness (E108).
check continuity between terminal 2 (blue wire) of ignition switch harness and accessory relay 2 (blue wire) in engine bay near airbox. check continuity between accessory relay 2 (black wire) and body ground.
check continuity between terminal 2 (blue wire) of ignition switch harness and accessory relay 1 (blue wire) near fusebox. check continuity between accessory relay 1 (black wire) and body ground.
the blue wire powers these relays to switch them on and is also directly connected to heads up display control unit, time control unit, audio, rear window defogger relay, meter illumination.
the blue wire gets power from terminal 1 (when ignition switch is "ACC") through white wire to green fusible link (rightmost) to white wire connected to the positive battery terminal (harness terminal E22)
also check the resistance while checking continuity.
checking for body ground
zerothread/159907
Im having problems uploading a pic. look for power supply routing in SOHC FSM (page EL-5)
