No power anywhere in the car
Panawholee1
Car: 240sx 89' w/ sr20 s13 black top swap
I had a ka24e auto sohc and i swaped a sr20 det s13 into it. I sent harness to get done. long story short i have no power going into the vehicle.
NismoDriver240
Car: 2005 STi
welcome to NICO
you definitely made a long story short.. care to elaborate? Out of that all I can say is... do you have a battery?
Check out he sr20 forums toohttp://forums.nicoclub.com/zeroforum/138
exhsturbine
Car: 1997 240
NismoDriver240 wrote:welcome to NICO
hahahahaha............... yes please, do tell.
Kalypso
NismoDriver240 wrote: ... do you have a battery?
do any lights work?
Panawholee1
Well yeah i do have a recharged battery. I am not getting no power at all to the vehicle, no int. or ext. light, no cranking.
I do have some connectors loose but there is no place to put them.
NismoDriver240
Car: 2005 STi
yea, the SR has extra connectors so those are ok. just go through and check everything again and make sure there are no cuts in the harness or anything stupid like that. Also, check the interior harness too
Hijacker
Car: '92 240sx Convertible
'94 F-150
Make sure your negative cable is grounded to the chassis and the intake manifold. SR wiring has nothing to do with your lighting, so you have something wrong at the battery
Panawholee1
Does the fuse box have anything to with it? Because i'm using the one from the car which is for a sohc auto
Kalypso
the ground to your battery should be attached to the passenger side of the block to a treaded 14mm ( or 12mm) hole under the starter.
it could be the ground cable, or dead positive cable,
bad terminal/s, dead battery,
this is simpler then you think.
whiplash willy
Car: 93 Coupe 90 SR Hatch
Check your Alternator Fuse (the large grey one in the fuse box in your engine bay on the passenger side). When that one goes, you will have 0 power.
Sphinxmunkey
Car: I change cars like underwear... well, more frequently than underwear.
I had this problem in the 300, the fuses are fusible links that look like a normal piece of wire, only way to check them is with a voltmeter or test light.
Good luck
