No power after car is off?
un_known
Car: 1990 Nissan 240SX
Well this is one thing in a list many things wrong with the electrical system in my car. For some reasons the seatbelt won't work after the car is off. Such as go forward when i open the car door. I think its something with a remote switch, because also my little clock in my gear pod is just blank, which means that theres no power after its off because its not keeping time. Please Help. Thanks
FactoryStock
Car: 1991 Nissan 240SX SE
Kind of a longshot, but have you tried checking the fuses? If they check out then you'll probably need to start tracing wires. Take a look at the connectors and make sure they're seated properly. Also might want to disconnect the connectors containing these wires and make sure the pins haven't pulled back or become mashed down.
UTWarrenG
****it, take it to the dealer...the auto seat belts are their problem to deal with....you have a lifetime warranty on them that travels with the car no matter what
http://www.nissaninfiniticlub....75980
un_known
Thanks it was the dome light fuse. I ended up just replacing the whole fuse box, just to start fresh. Thanks again.
