Philsnotfalling »
https://forums.nicoclub.com/philsnotfalling-u10849.html
Sat Sep 01, 2007 11:12 am
Bleed, Bleed, Bleed and then Bleed some more. Empty systems take a long time to bleed. To me it sounds like your master cylinder is bad. Buy a new master cylinder and slave cylinder and I would recommend getting a one piece stainless braided clutch line to eliminate the dampner. I just bought my nabco (which is oem) master and slave from frsport and my AP clutch line from 240sxmotoring. don't skimp on the master and slave this will be my third set of clutch pieces because I bought cheap junk from auto part stores. Total cost this time around about 120. Bench bleed your new system and install as on unit into the car. Then check your adjustment on you master cylinder at your clutch pedal.
