No parking lights and high beams only..
SUITE E
was an interesting ride home last night with flashers on so no one rear ended me. I was fiddling with the lamp that lights the window switch for the left rear window. You know the little blue bulb. I must have shorted out something as I heard a little click and next thin I know I have no gauge lighting, no low beams, no rear parking lights. Just high beams in front no matter the stalk position. Fuses are all good, at least the ones I see. Did I fry a relay? If so does anyone know which one? Thanks for your help guys.Rich
SUITE E
I am such a dumass. found the fuses under the hood and of course the 10 amp was cooked. All is well. Til next time...
DAEDALUS
Car: 1990 Infiniti Q45
Check your bulbs for signs of burning/overheating. Fronts would be my guess, but check them all. The fuse should not have tripped.
gniknave
Car: 2000 Audi A6 2.8 Quattro
2008 Honda Civic EX (Sedan)
Wish I saw this post earlier, the same thing happened to me 2 weeks ago.
