kouki munster wrote:Pull the oil filter off and stick a funnel with a long neck in the holes and dump some oil in the block, then fill the filter with oil and put it back on then crank it again. Ka, sr, and rb oil pumps don't work to good if they are dry, you have to get some oil in them so they can get enough suction at crank rpm to pull the oil up the pick up tube.
It would also be in your best interest to dump some oil over the valve train.
Thanks!!! I read u could like pre-fill or pack the oilpump but had no idea what ppl meant. I will do that.
OutToWinPAHC wrote:Oil flows up the galley to the head and down the other galley to the pan right over the crank wetting it along the way.
If I drain my oil and re-fill it the normal way (not removing any cam covers) besides not having fresh oil along the intake cam side (still should have assembly lube tho) will it have the same drain/oiling effect on the crank? I just wanna see oil from the turbo return and I'll feel satisfied to start it. It should pump oil up the the intake side of the head nearly instantly anyways.
