No oil filter bracket present? Help
emiliog2276
Car: 1990 300zx 2+2 NA
2002 Nissan Sentra GXE
Helping a friend out with an oil change I noticed there is no oil filter bracket present at all. The is no way to fit an oem filter because of the lack of the bracket a smaller one has always had to be used. The oil pressure sensor is located next to the filter but ive noticed on the oil bracket there is a a pressure sensor screwed on it as well. So what happened here? Should I attempt to install a oil filter bracket and use the sensor that is screwed on the the bracket but also leave installed the one that is currently installed next to the filter at the moment? Also is the connection from the engine to the oil filter bracket suppose to be threaded or did someone add this so they can use and oil filter without the bracket? Thank you
Uploaded with ImageShack.us
zcar93na
Car: 1993 300zx 2+0 N/A 5-speed
1984 W150 Ram (Getting a Cummins swap)
1984 Isuzu P'up diesel(sold)
It looks as if someone took the oil filter tree off, and they relocated the sending unit to the port beside it. The auxiliary sending unit for my glow shift gauge is there. I don't know why someone would take the tree off unless they broke it somehow
zcar93na
Oh and the bracket for the lower bell housing bolts are missing :confused:
emiliog2276
zcar93na wrote:Oh and the bracket for the lower bell housing bolts are missing :confused:
Can you provide further details on this?
Also to the port you mentioned where you currently have the auxiliary sending unit. If that unit wasnt installed would it just an empty port or would something have to be there? Just wondering if i can safely remove the oil pressure sensor to install it on the oil filter bracket.
zcar93na
Give me a minute to dig up a photo on the bell housing bracket. But there is a plug that goes in that port, 1/8" bsp IIRC
zcar93na
This is for a z31 but it will give you an idea. It bolts to the two hole directly under the oil filter, the lowest ones in your picture, and ties the block to the lower bellhousing.
http://www.ebay.com/itm/84-89-85-300ZX- ... 0151412188
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Just get a used oil filter tree and install it with some silicone RTV. Someone obviously ghetto rigged that for no reason. And yes the bracket that zcar93na is referring to is missing. It bolts between the block and bellhousing to make the whole thing more rigid.
emiliog2276
Thank you so much.Is there suppose to be a driver side and a passenger side housing bracket i was checking out twinturbo.net and there was a mention of this.
zcar93na
yes, there are both a passenger and driver side bracket. The driver side is 1 piece and the passenger side is 2 pieces
