I don´t have any o2 sensor to check in my power fc commander. I have a s1 rb25det , and I think that the power fc doesn´t use the o2 sensor to make any change in the fuel map.jrb92se wrote:i was checking the sensors on my pfc and realised im getting no o2 sensor reading. i havent really investigated it yet but i figure it just needs to be replaced I READ THE PART# STICKY but i couldnt find a p/n for the s2 rb25det o/2 sensor. which one should i use (oem nissan,bosch etc.) thanks guys!!
No. It's shown in the sensor voltages. and No, the PFC does use o2 sensor for closed loop fueling unless you turn it off.al_v wrote:I don´t have any o2 sensor to check in my power fc commander. I have a s1 rb25det , and I think that the power fc doesn´t use the o2 sensor to make any change in the fuel map.
This is funny , I was checking my o2 voltage ,and no change at all, is always at 0.02 v , so I assume that my o2 sensor is bad too......gawdzilla wrote:
You can use almost any 3 wire o2 sensor and wire it in. I think the z32 o2 might be plug and play.
