peashooter »
https://forums.nicoclub.com/peashooter-u84222.html
Sat Dec 22, 2007 5:04 pm
I am new at working on a nissan. HELP. I recently replaced the rings in a 1992 240sx ka24de . replaced the clutch, pressure plate, throwout bearing, and knock sensor. I had the heads checked, all OK. The timing postion marks I made were all cleaned off when they cleaned the heads.I think I got them right with the help of this forum. I have a problem with the engine running right. At about 3000rpms I can't get any more speed. It acts like it has a speed limiter . I floor the pedal and it wont go any faster. It idles steady at about 1200 rpms .When I tried to set the rpms to 700 it runs erratic and I can't adjust the timing to 20deg. btdc. according to my timing lite it is around 60-70 deg.btdc. A cold air intake was added by the previous owner w/out a pcv valve. they have a hose running from the tube on the valve cover to the intake tube.
