jons »
https://forums.nicoclub.com/jons-u55281.html
Thu Mar 01, 2007 6:05 pm
carfrk666- I don't think so on a J30. Its got belts and tensioners, not chains and ramps.
It looks like the pump is accessible by "only" removing the oil pan, which is not a trivial task, but sure beats pulling the motor.
BTW, if its of any relevance, after replacing the injector, the car was very hard to start. Took a lot of cranking, but eventually fired up and all the idiot lights went out. The idle was surging between about 800 and 2000 rpm. After several minutes it settled down, but was pretty rough. But it smoothed out off-idle. It ran strong for a couple of miles (no low oil light) even though the idle remained rough, almost to a stall. Then the light started to come on, and....
I will first check the oil filter to see if anything unusual is in there. Then I think the next step is to drop the pan.
Jon.
