95-J30tt »
https://forums.nicoclub.com/95-j30tt-u40286.html
Sun Feb 25, 2007 3:26 pm
what is the milage??, the oil pump is crank shaft driven, to replace it, the oil pan has to be dropped which means an engine pull.... the oil pump is listed in the 120K mile engine maint. .... , if you lifters are ticking, or you hear knocking coming from the engine, then the oil pump is pretty much gone, you can check it using a oil pressure gauge, remove the oil pressure switch and put in the oil gauge and turn the engine on, and see what you get....
i hope this helps, good luck
