PapaSmurf2k3 »
https://forums.nicoclub.com/papasmurf2k3-u3044.html
Sat May 12, 2007 7:22 am
I was always under the assumption that the markings on your cam sprockets (assuming they are stock cams) were supposed to be around the 10 and 2 O clock positions when cyl 1 was at TDC on compression stroke. Also, the lobes should be facing exactly opposite each other, and should be pretty parallel to the ground at TDC compression stroke. Hope that made sense.Like this: (NOTE, this is 180 out, so cyl 4 is TDC compression stroke)^ Note the cams are in backwards in that pic (exhaust is on intake, and intake is on exhaust), but still, the dowels are ligned up the way they should be.It looks to me like your cams are off. (Or mine are off)
