What size tires are on your car in the picture in your signature? Car seems lower than stock to me?Woot! wrote:I have the 7 spoke G35 wheels (see my signature) and they seem to do good.
Agreed. Check out 3QJ's Q with the 18x8s from an FX35.Q451990 wrote:There's a couple of pics here of first gens with 18" FX35 wheels. From an asthetic standpoint, I think they're perfect on the Q. Can't coment on the ride quality...
Heath
There should be a link somewhere of my original Q with both the 350Z "Track Wheels" and the Murano "5 Spoke". All in all I didn't think it hurt the ride at all, but make sure you have good shocks/springs. If not, you'll feel the extra load in the old suspension parts.qship96 wrote:I go back and forth with the idea of ditching the stock 15" wheels for 18" with 245/45/18 tires....here are my 2 main concerns
1. How much will ride deteriorate with the 18" compared to stock,especially on less than perfect roads?
2. How do they look with stock springs? I have no interest in lowering springs.
Anyone have experience with ride quality,and pictures posted here with 18" wheels/tires on stock springs on a 90-96Q ?
The Michelin PS2 disproves this concept that I had prior to using them. Also, with and 18x8 and the correct offset, a 245/45-18 may be employed if the car is not dropped.96Qowner wrote:I'm old school and like the comfortable ride along with the handling, so I'd urge you to go no bigger than 17s.
17" tires are cheaper, too.
I think Jeff Williams is running those. Might try searching to see for sure.qship96 wrote:I am considering the ASA AR2 in a machined finish 18 by 8 wide with +40 offset as rec. by Tirerack with 245/45/18 tires {any fit issues? TR lists 245/40/18 for the Q,however I want slightly taller tire on stock springs for less wheelgap and ride quality}.
Does anyone here have any experience with ASA wheels? I believe they are an offshoot of BBS,wonder if quality is near that of BBS?
Tirerack has these on closeout sale for only 169 each.Guess I would order an extra wheel as a spare in case one got damaged later on.
TR will reveal weight and strength data if it is not on the website. Ask. +40 mm is a little tight to the upright.qship96 wrote:I am considering the ASA AR2 in a machined finish 18 by 8 wide with +40 offset as rec. by Tirerack with 245/45/18 tires {any fit issues? TR lists 245/40/18 for the Q,however I want slightly taller tire on stock springs for less wheelgap and ride quality}.
Good choice unless you want to spend a lot of money.captainluigi wrote:luving feelings returning. after all the # crunching, reading pro & con i am now somewhat leaning towards a set of michelin pilot exaltos on the old bbs wheels.
Timonium is a suburb in Baltimore County just north of Towson, and about 10 miles north of the inner harbor of downtown baltimore.Home of Nationwide Infiniti,one of the first Infiniti dealers!captainluigi wrote:DITTO! of topic. serious question Qship. is timonium a rare metal? could not find in my periodic tables.
