no lights when doors opened
redsworld
Car: 2012 M37x; Touring and Premium Package
I was replacing the front over head bulbs with LEDs. Now the lights do not come on or fade off when entering /leaving car. I can manually turn all on at each switch - both front and rear. The foot well lights are not working either. All 4 puddle lights and exterior lights are working. I have pushed every over head switch. 2012, M37x, 26,000 miles.
Thanks. Rob.
mikedamageinc
Car: 2012 Infiniti M37x Touring
1999 Chevy Camaro SS
1997 Toyota Land Cruiser
2008 GMC Yukon Denali
It's your BCM, you fried that output. Don't feel bad, I did the same and so did many others. I looked at the diagram and I'm pretty sure you can bridge the output from the door mounted lights if you really want it. I didn't because the door lights are all I like to come on unless I need to look for something.
redsworld
I still have 5 months of factory warranty. You think they will repair it?
Mjkkb2
Car: 2018 Infiniti QX60 AWD
2011 Infiniti M37S
2011 Nissan Quest
2001 Infiniti I30t(sold)
Yes, just put the original bulbs back and play dumb when you take it in..
reggiebrown40
Car: 2018 Infiniti Q60 Red Sport
2011 Infiniti M56x - Dead
redsworld wrote:I still have 5 months of factory warranty. You think they will repair it?
I used to think it was the BCM, because it was the bcm on my Q45. It isn't the same on the M56. It's the entire wiring harness that runs through the body of your car plus a jumper bar that is located across the back of the dash. You could probably repair the wiring but Infiniti sells both parts as one single part. The total I was quoted was close to 3 grand, without labor. If I were you I would tell the dealer that the lights just stopped working and see if they repair it under warranty. Good luck. FYI my dealership repaired mine a few weeks ago (sort of) They jumpered it off what seems like the door handle lights. The interior lights and footwell lights work, but you lose individuality brightness when you open a single door. Cost me 500 bucks to do.
Debonair
Car: 2011 Infiniti M56
This car with its lack of fuses is overly sensitive to shorts. Very poor design aspect of it. :tisk:
Everyone PLEASE disconnect the negative battery before doing ANY electrical work, even basic stuff.
Ilya
Been there, done that. Hopefully your dealer is as cool as mine lol.
redsworld
Thanks for all the replies. Should I remove all the LEDs I installed? These were the last 2 when it happened, I would have to go thru all of them again. Thoughts ?
Frog
Car: 2011 Infiniti M56 S
My m56 needed a new harness as well. Done under warranty. Be carefull
Ilya
Yes, remove them all, get the car fixed, then install them all with the battery unplugged.
TreyhunnaM37x
Car: M37x
See this is why modifications on a luxury car make me nervous. I did a lot of modifications to my Chrysler 300 and my Chevy Malibu but I don't think I will be doing too many on my Infiniti. Smh
Debonair
TreyhunnaM37x wrote:See this is why modifications on a luxury car make me nervous. I did a lot of modifications to my Chrysler 300 and my Chevy Malibu but I don't think I will be doing too many on my Infiniti. Smh
I have to admit that I had my battery still hooked up for most of my bulb changes. Thankfully I did not short any. But knowing what we all know now about this car using a harness as a fuse, that negative cable comes off before I do any electrical. And I have done a bunch already and had no issues.
There is no reason to fear it, just take the proper precautions. Loosen and remove the negative cable from the battery and all is well.
