no lights... need help!!!!!!!
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
lil89ram50
Car: 1985 nissan 720 1989 dodge d50 1979 chevy luv
ok so i jus bought a 1985 nissan 720 with the z motor, and 5 speed for 200 bux!!!
well i got it home, drove ok, hessitates pretty bad tho..... guessing vacume leakes? anyone got any diagrams on which ones i dont need? i am going to remove everything i dont need........ i dont have to pass smog, so all i need is my motor and alternator...... any one got any pics of theirs or someone elses done like this? maybe someone that races theirs?
and my main problem that i didnt kno bout untill i jus got pulled over, i have no tail lights! no blinkers either! but the brake lights work...... oh and none of the gauges work or light up..... ive checked all the fuses by the kick panell and there all good.... is there any other fuses to check? what else could it b?
dogred
Car: 1983 D720
I kind of have the same problem but mine kick on after 2 minutes. I am also searching this out. Your problem could be with the dimmer switch on the dash. I will have to check my wiring diagrams. I have a 83 so there is probably some similarities.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
I'll try to get up a vac diagram later.
PEZi
i race mine... i'll get some pics up soon cause i'm in the middle of my deletion project
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
when I got my 85 begining of this year, it had no lights back or front, no turn signal (blinkers), and no fuel gauge. All the fuese were good and all the bulbs were good. checks showed the wires to the rear were severed, the control for the wipers and head lights was not working and the fuel gauge wire was broken off at the float. here is what was done. 1 reconnected the wires for the rear going over the diff, did that myself. 2 got my cousin who does electrical work to assist with repairing the switch. 3 used a small all thread bolt and nut to reconnect the fuel wire with the insulation from a 14 gauge wire to prevent grounding, did that myself also. make some checks and let us know the results:dthumb
keep the rubber down!!!
lil89ram50
well i got the lights working! it was just a yellow fuseable wire coming off the battery that was disconnected..... but i still have a slight hesitation, and the spring for my choke arm on the carb is gone, so the previous owner had it wired shut, so i need it fixed by winter... and i would still like that pic of the truck with no vac. lines.... thanks!
Return to “Datsun 720”
