No labels for the relays
jwill3212000
Car: 05 altima 2.5 sl
I have a 2005 Altima 2.5 SL. The left headlight is out, the fuses are good, and the bulb works on the other side. There is no labeling for the relays in the fuse box under the hood like for the fuses. Which one is which so I can swap the relays and see if one is bad. The dealer wont give me this info. Help!!!!!
kuhan
Car: 2008 Nissan 350Z Enthusiast 6spd
usually there is a diagram printed under the fuse box cover. Did you take a look at that?
relays typically dont go bad. are you sure you checking the right fuse? if you have a meter, check the continuity between two legs of the fuse. It should be shorted (0 Ohm). A blown fuse would read infinity. just wondering.
jwill3212000
Yes fuses are good. And no, there is no label, and nissan aint giving up the golden grail. I bet if you take the cover off your fuse box, you will see the same thing, a nice pretty label for the fuses, but nothing for the relays.
