well
float_6969 wrote:What I'm getting at is the combustion won't make it boost less. If anything, severely retarded timing will make you run MORE boost, since you're wasting energy out of exhaust instead of using it to push down the piston.
If you're sure you have a 7psi spring, and you're only getting 5 psi, you've either got a big boost leak, an exhaust leak at the head or the turbo, your spring isn't really a 7psi spring, or your boost controller vac line routing is wrong.
If you had a boost leak, the car would run like azz off boost. It would have to be a BIG boost leak to cause you to loose 2 psi.
If you had an exhaust leak, you'd hear it.
It is possible that depending on the brand of wastegate you got, the spring is the wrong one.
Where do you have the vac lines routed for the boost controller?
Why do you have a boost controller if you're only gonna run wastegate pressure?
well it runs like it doesnt have a boost leak, out of boost its a champ.
its a TIAL 38mm, and i spiked 5.5psi today. im starting to think exhast leak before the turbo, but it doesnt ound like one, and it would have to be a big exhaust leak to make it not boost that much of a difference.
there is a vacline from the compressor to the controller, with a tee and a line going to the bottome port on the wastegate, then there is one on the top port going to the boost controller, i am like 99% sure its hooked up right, i literally looked at HKS's install directions while hooking it up, i even started over and did it again with new vac line.
im not sure what it could be, the ONLY things that have changed is the spring rate, intake cam, and head gasket/studs, and 444 injectors since i blew it,the old wastegate was an OBX with a VERY stiff spring, so i trashed that for a TIAL, before i could run 15psi no problems.
also, another thing is the knock sensor is out, but thats it.
i ned to figure this out NOW
