02wrxmazdab2200 »
https://forums.nicoclub.com/02wrxmazdab2200-u253873.html
Mon Jul 13, 2015 2:12 pm
Hi I'm looking for any help from practically anyone. I've checked nasioc and the sti forums and they all give me the same links to the guy who posted here about a fuel problem. Well I've replaced the whole fuel system from a donor wrx that runs I've been building a Mazda b2200 with. Wrx frame and everything just Mazda cab and bed everything is done engine ran fine in my wrx even after I rolled it over. We took the motor and transmission out everything ecu wiring harness etc etc. Ran the motor on the ground even to make sure then we finished all our cab work hooked everything up but now we got no fuel injector pulse or fuel to the injectors. The fuel pump does not turn on when key is turned but when key is turn to off the fuel pump turns on....but still no pulse to injectors either when off.... Like I mentioned before I replaced all fuel system relays controlllers only thing I cannot do is see what the ecu says due to my tactrix cable or box piece is screwed up and I don't wanna buy a scanner to just figure this out T.T also the whole motor transmission rear diff is jdm and security light won't shut off even when we disable it through the way Subaru says too, my key does not have achip nor did it come with one. Any help be appreciated.
