No injector pulse
Xearo101
Car: 2011 Infinit M37
1991 Ford F150
1971 Lincoln Continental
I recently overhauled (new rings. valve stems seals, chain tentioners, and all gaskets/o-rings/RTV) a 2011 M37 engine. Now after install and prime I have no injector pulse. Checked for a short to ground on all signal wires and checked continuity from ECM to injector harness. All checked out good, grabbed a few cam sensors and still no injector signal. Fuel pressure is there and we have spark. The starter engages and the engine turns over but does not start. So my question would be, is there some kind of anti-theft or specific sensor I should look into? All-data (No-Data) is very limited on a proper wiring diagram for the crank and cam sensors and mostly just tell me to use Consult, which of course, I do not have. Any and all input would be appreciated. Thanks
lovemycarM35
Car: 2014 Lexus GS 350
With F-Sport Package
Nebula Gray
19" wheels
12.3 inch display
Navigation
Can I Ask why would you need to do this on a two year old car was it having issues how many miles
Xearo101
1991 Ford F150
Sure, the car was a previous lease. "They" apparently never change the oil from day one. Nissan voided the warranty because of sludge. When i got the car it had a fouled plug on the #1 cylinder. The coil on that cylinder was also replaced as it was weak. After the plug and coil was replaced it was running on all six. But it was burning oil very badly on that cylinder, fouled the next plug.
Xearo101
1991 Ford F150
34,211 miles on the counter.
svard75
Car: 06 M35x
I'll throw some cents in. Try connecting the bcm to the Ecu and use the paired key to rule out security issues. On some alarm systems they use relays to deactivate the fuel pump when armed but u said there is pressure so perhaps they keep the injectors from firing?
