dstredi »
https://forums.nicoclub.com/dstredi-u132157.html
Tue Nov 24, 2009 5:10 pm
I installed the Ca engine into a 69 Datsun roadster SPL311. I fired the engine and it seemed to run fine. I continued working on the installation thinking everything was fine. I cleaned up all my wiring and permently mounted all relays. Now car won't start. Thinking I crossed a wire some where, I took all the wires back apart an checked powers and grounds. Still no start. I have no injector pulse. This happened in August. I have studied wiring diagram and I do not see the problem. I have replaced the ECU thinking that I may have shorted something in it. I have replaced dropping resistor and I have replaced cam sensor. I have power to the injectors and I can ground a test lite and make each one fire. I am very stuck and could use some . Thanks, Dan
