sewell94 wrote:I am doing a swap for a friend. We have no injector pulse. I first assumed the injectors were stuck so to make sure i our some gas into the intake and it fires and runs for a minute. i then check the fuel pressure, it appears to be good. So i check the voltage to the injectors and there isn't any pulse to them. Obv i have spark etc etc. The check engine light comes on as it should, then turns off when u try to start it. What would cause this? i double check and i didn't see any grounds that i missed, what in the wiring could be screwed up?? any sensor that could do this?? I don't know nissian efi stuff at all, so any help would be greatly appericiated. thanks in advance
First of all, do you have an injector resistor? If you don't or don'tknow what it is, then there's your problem. You said you checked for voltage and there isn't any pulse, which is it. Either you have no voltage or pulse! But if you have one or the other, you have some serious wiringi issues up-to and including, a bad ecu. Good luck with this one...............
Dee
