jtreign9097 »
https://forums.nicoclub.com/jtreign9097-u274122.html
Mon May 08, 2017 3:07 am
I "think" I remember Q45Tech mentioning a bad ECU with this type of failure once, but it's very rare. It sounds like you know what you're doing with the testing - so just be sure heed the warnings in the FSM about not testing through the ECU's ground terminal.[/quote]
i took ecu apart found a huge spider net and water corrosion on the pins on the bottom corner.. cleaned it up and no more misfire or engine lights.. but when i run diagnostic mode i get code 51 34 21 16... now i know 34 is knock sensor.. and other codes may have been caused by me unplugging things but i don't have any current engine light on so were these codes old stored ones?... also now that its running smooth now rpm is rough all the way to 2,000rom and a miss at 1500 rpm... basically a a lot of hesitation until 3000 then it smooths over... should i try cleaning the maf over and over or is this an IAC issue typically with this car? i know in many other cars the tps is what can cause this but not sure they go bad on these cars commonly.. Car does has 209,000 miles and i didn't get a code for it
