NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Sat Jun 18, 2005 2:15 am
You need to be able to check the crank angle sensor input to the ecm, the only way to do that is with a oscilliscope. A volt meter will not work to determine is the number 4 pulse is getting to it.
You could pull the distributor cap off and then the rotor and finallay the plate under the rotor and look at the pick up wheel in there and make sure there is nothing covering any of the holes on it. dont remove the wheel and be carfull with it as it is delicate. If you see a spider web or something else covering some of the wholes wipe it off and recheck the car.
