geofthriller »
https://forums.nicoclub.com/geofthriller-u52902.html
Tue Sep 25, 2007 6:51 pm
MY SETUP: '96 SE S14S13 SR20DET BLKTP 1.2 MTL HG COMPRESSION: approx. 165/163/160/160S13 SOHC MAFS14 turbo @ 7 lbsWALBRO 255 w/ NISMO ADJ. FPR
Has 3.7 liters of OIL3/8 tank of GAS50/50 MIX of COOLANT
I drove the car already for 1,000+ MILES with NO sign of a problem, till I installed side skirts, and when I made the Oil+Filter change. My motor does not start, and this is what has already been looked @:
Timing is set to 15 degrees below TDC
Spark at all 4 coilpacks
Light on ecu lights up when KEYED ON
Swapped ECU with a known working ECU= SAME SITUATION
Fuel pressure at approx. 60 psi
Each of the 2 wires on all 4 injector connectors have NO PWR when KEYED ON
Battery + Oil pressure lamp light up on gauge cluster which NEVER lit up in the past.
No blown fuses in both fuse boxes, except for wipers-which i dont have because the wiper plug was chopped off by the previous owner... if at all relevant..
Swapped out BLUE relays (@ the moment dnt knw function of BROWN relays)
Engine harness has no cut or ripped wires!
If you have any idea what the problem could be, PLEASE dont hesitate to help. Been banging my head against the wall for almost 2 weeks now!!
THANK YOU FOR READING!
