ok so Im having a huge problem with this and i need some help, been on google and forums all day. let start with the car and from the beginning. 95 se was auto but swapped to 5 speed but previous owner. they also broke the keyoff in the ignition switch and they put a push to start panel in. had the car for a year and never had any problems like this. I swapped a s15 sr in dec.... 3 weeks ago drove the car to my garage to park it cause we were gonna get snow, I parked it there and used my key to open the trunk and it broke off, got pissed left. today i went to go drive it because it was nice out for once. my doors were locke but the broken key was hanging out of the trink just enough to pull it out, so i though i could put it in the driver door and use the rest of the key to unlock it but it didnt work. so i used a coat hanger and pressed the unlock button. when I got in and flipped my switches to start it nothing at all and it a brand new battery i got on jan 15th. my head lights, tail lights work interior lights and door lock work. i didnt notice the security light was a constant on? never seen that before so i disconeccted the batt to see if it would reset but nope . so like i said i did research found the security box unplugged it and plugged it back in now is flashing seem a little fast then normal maybe not sure. then i checked all the fuses and they were good. in other post saw there was some red connecter that melts and causes this problem.. but i couldnt find that on mine? i got my test light out and check the constant 12v that should be going to the ign switch and nothing. started looking up relays couldnt find any info on witch one were the ign so i pulled known good one off my other car. still nothing. the only one i couldnt try was the clutch inter lock relay because they were different.
I'm convenced its either a relay i missed or the security system locked me out because the broken key in the door? or even possibly a bad ecu bit if that was the case id still have a cosntant 12v at my ignition switch...? I am completely lost on this and hoping someone on here has some advice or direction i may have over looked or missed. I also have a factory keyless entry pad, but never used it because the battery was dead so i even replaced the battery today and it didnt work so i looked up how to reset it but couldnt because you have to put your key in the ign switch and pull it out multiple time but i cant because there a key broke off in it... go figures! PLEASE HELP ANYONE!!!
