fun240 »
https://forums.nicoclub.com/fun240-u58771.html
Tue Jul 22, 2008 6:01 pm
Well the topic isn't as bad as it seems, or is it?
Basically, the car will finally start at this point. It will idle below 500rpms, and jump. Stay alive for about 3-6 seconds, then die. I finally got it to crank, after it shut off on me twice. When it started to cut off, I pulled up to a stop sign and it idle'd between 400-700 up and down, up and down. I got to my buddys house, and then it wouldn't crank at all. I replaced the fuse for the fuel pump because it was blown. Then we finally adjusted the timing right to get it to crank. And now it does that. Won't stay alive, And when i give it gas, it dies right out. Idles between 400-700 up and down up and down, then dies. Gas or not. With the MAF unplugged, it will idle right at 500, then i gas it, and dead. I just stuck a 96' KA into my 92' body. Everything was fine all day, then this happened. I am using, the 92' Intake, 92' Airbox/Intake to Throttle body. 92' Injectors. 92' Maf. And the fuel pump/lines from pump.
Everytime i give it gas, it dies. It won't idle, It rough idles, if anything. Took me forever to get it to crank. Takes forever for it to crank. It won't stay alive with the MAF unplugged, or plugged. It dies after 5-6 seconds. Period.
Anything sound familiar?
