No Idle?
ZOMG.SR20
Car: 1990 s13
so my SR was running like poo as some of you may remember but i replaced the IACV and it RUNS fine when on the Gas as soon as i let off the revs drop like normal but then keep going till dead idk i checked for vac/boostleaks but none....
ZOMG.SR20
Car: 1990 s13
help?
jeremymr06
ZOMG.SR20 wrote:so my SR was running like poo as some of you may remember but i replaced the IACV and it RUNS fine when on the Gas as soon as i let off the revs drop like normal but then keep going till dead idk i checked for vac/boostleaks but none....
when we were troubleshooting we found1: the hose going from the intake to the mani for the aicv was kinked off, check all the vac hoses to make sure they are good and not kinked... 2: check power to the aicv.3: check for leaks. i have a safc so i added fuel to get it to idle smooth but i still havent found the leak.
good luck.
my post with similer problemshttp://forums.nicoclub.com/zer...62452let me know if you have had the problem and what fixed it...
ZOMG.SR20
Car: 1990 s13
ill check everything again...... and how did you check power to IACV
GoTRicEo0
Car: Slowest crap the earth have ever seen.
Even with the idle screw all the way open it dies?
ZOMG.SR20
Car: 1990 s13
yup
rc1honda
Car: 1992 240 sx
2007 BMW 335xi
2008 Honda CBR1000RR
What Maf are you running? This can happen with the atmospheric BOV. You can tune this out fomr happening by tuning the Decel Air on the SAFC. When the BOV vents it lets out air that was already meteterd, so the ECU thinks there is more air in the system then there actually is. Causing it to run rich and bog out. Try recirculating your BOV and see if the problem is still there and double check for vac leaks.
ZOMG.SR20
Car: 1990 s13
so if I get a SAFC i can tune the ATmospheric? cause i have a RFL BOV right now its hard to recirc that
ZOMG.SR20
Car: 1990 s13
ok so i recirced the RFL(yes its possible)
now i get thishttp://www.youtube.com/watch?v=FuoCQFy7edI
ZOMG.SR20
Car: 1990 s13
i think its the MAF
