no horse power
bryanterick
Car: 1992 nissan 240sx
hey guys I have a nissan 240sx 1992 with aftermarket intake, my rpm moves up and down at times all the way down and the car turns off, and also my cooling fan it's always on is this suppose to be like this ,
s13sr20chris
yeah, the fan is mechanically driven so it should always be on. as for idle hunting...try pinching off the iacv hose to see if she stalls.also, monitor maf voltage(if you have a multimeter) while the idle is hunting.vac leaks can cause this sort of thing too.when was a good factory tune-up done?
NISTECH
check your coolant temp sensor connection. I am assuming your saying your secondary electric fan is on. when the car goes into coolant sensor failsafe it turns on the fan since it doesnt know the actual coolant temp.
bryanterick
a real factory I have not done one yet/ I was thinking this weekend but what really is a factory tune up
s13sr20chris
nissan cap, rotor, and wires. ngk v-power plugs(no need for platinum or iridium, v-power is a great copper plug).
youngmanvr4
Car: 94 3000GT VR-4/90 240sx
Check out my thread. Maybe it will be of help to you. I still haven't figured it out yet maybe it could help you out or where to start...or finish lol.
zerothread?id=146210
