Ditto here. The heater doesn't even start blowing until the engine is heated to a certain point. Thereafter it works very nicely; even in idle.Alphax wrote:My M wont blow until the engine is heated up. I was assuming it was designed that was to prevent from just blowing icecold air on us. No heat until its actually heated air. Are you sure its just a cold engine block and as you drive its heating up then out comes the heat? or are you stopping warmed up at idle and its shutting down.
Thx for the input!qship96 wrote:If you want fan to blow air before coolant gets warm just manually adjust fan speed, but expect cold air to blow from dash vents til coolant gets hot.Read your owners manual hvac system operation for more details.
I would think if you has a open thermostat the engine would not get up to operating temperature easily.msvara wrote:You missunderstood. I don't think it's the level of the coolant but rather the thermostat that is stuck in the open position. You can tell without taking it to a mechanic because a cold engine uses more gas. Check your L/100km. I do city/hwy combined and get around 15.1l\100 for the M35X.
M
This is indeed how Infiniti's have been doing their thing for many, many years now.rsg123 wrote:My car doesn't start blowing air until about 4-5 minutes after I start driving when it is very cold outside. I appreciate not having freezing cold air blown at me, and I have always thought this was a feature rather than a problem. In the summer, the vents turn on very quickly.
The challenge is how to defrost your car when the blower will not engage for 15 minutes?szhosain wrote:
Z
I can turn on defrost and turn the fan up to high but it will NOT engage up to 15-20 minutes later.
So i have to come out in the morning, 20 minuted before hand, to start the car and let it run to hopefully get the defrost to engage.
I cant drive the car if its wont defrost.
I owned many a car and none have done this.
My Zepher, Which breaks all the time, defroster turn right on and has the windows completely defrosted in a matter of a couple minutes.
works great.
I already hate getting up early now i have to do it 20 minutes earlier? That sux
I know in the east they think different but they can NOT think that differently?
My garage is not heated
Ok at least i know tmena and i are not crazy.msvara wrote:That's definitely not norm. I just tried it out and dead cold start. Been sitting in the -4 c weather for 8 hours and as soon as I hit the defrost button it started blowing hard. This was all automatic. It was blowing cold air yes but it defrosted the windshield pretty quickly. You got a problem with the control unit.
CHEERS!
