Got tires, e-test, insurance and plate sticker all in one day. Pretty productive. BUT.. ofcourse theres a but... There is no heat from the vents.
With the car idling, the car will only blow cold air, even when set to 85*, unless you start moving and are on the throttle then some warm air comes out, but still not as hot as I figure it should be.
I let the car cool down and popped the rad cap and it was full and clean, aswell as the overflow was within the lines. The radiator is also fairly new
What gives?? Please dont tell me the heater core is clogged, that cant be easy to access!
