I'm thinking maybe it's the thermostat stuck open?fluffybunny wrote:I was checking this out this morning, because I am having the same problem with my Z. My car only blows cool air and no heat. Before I tear my dash apart to get to the heat core, is there anyone that has experience with this problem before? I checked the door motors and they operate fine, allowing air to pass through. I was thinking maybe the valve letting water into the core may be the problem. Does anyone know where this valve is located?
Not sure what you're referring to but I can do a search for the cabin temp sensor location I suppose..Ace2cool wrote:there's an automatic diagnostic built into the climate control of our cars. here's a write-up:
http://www.ttzd.com/tech/autocc/autocc.html
If that doesn't help, then pop off the little plastic trim in the T-bar that has the map lights in it and check your cabin temperature sensor to see if the wires on it are crossed, giving an infinite temperature reading.
Happen to know where to thermostat is located in our cars?Ace2cool wrote:there's an automatic diagnostic built into the climate control of our cars. here's a write-up:
lol that's what I've heard. Do I need to disable the air bag?
