slickroger wrote:Have you done this?Is it worth doing?
Nope, I left mine unmodified. I've read in a few posts that it's extremely simple and it takes no more than five minutes, you can just cut along the seams. Is it worth it? Probably not. The filters are somewhat pricey ($30) and I have no allergies and I really doubt it would be a noticeable difference (smells, etc.) since they aren't HEPA filters or anything comparable. Also, a dirty/clogged filter is a known cause for the fan amplifier failure. The fan amplifier is cooled by the air which passes through the cooling unit, a clogged filter will restrict the air movement and will cause the fan amplifier to overheat, resulting in replacement.
