Denver90Q »
https://forums.nicoclub.com/denver90q-u84970.html
Fri Jan 11, 2008 9:31 am
This is a 1995. The temp gauge is suspect since needle will peg at bottom for first 5 minutes then usually shoots up to slightly past middle. The heater will blow very hot once operating temp is reached but only for a second or two. The condensor fan will come on sometimes even when the car has just been started at subzero temps and ACC is switched off. Also noticed that ACC seemed to hunt or cycle on off last summer with A/C on.
My other problem is that the rear defroster is not working. Not sure if ties into the other problems but I did a continuity test and it checked out OK.
