vannaksao »
https://forums.nicoclub.com/vannaksao-u157428.html
Wed Sep 22, 2010 6:55 am
I've looked for threads that might help, but I either can't find one that answers all of my questions, or the issue is half accurate. I'm going to try and make this as short and detailed as possible.
I was driving to work the other day (going up I-95 on Monday at 7am), kind of sitting in traffic- approx 30-40mph, stop and go. Woohooo! All of the sudden, I kind of feel my car bog, and it feels like I lose oil pressure. I step on the pedal, but the car barely moves, and it barely revs. I look down at my temp gauge and the tach is past the bar and hovering above the H! So in a panic, I turn up the blower (dial shows 4 fans), and max the temp to 90 degrees. It helps out a little- I see the temp start to drop a little. Also, luckily, the traffic starts to disappear and we start to move again. Now I'm going about 80mph with the fan and temp as high as they can go, and tach comes back down a little lower than halfway, where it should be. THEN, while I'm still driving, the hot air thats blowing turns into cool air. The temp is at 90, but the air is super cool. I get to work, shut off the car, and go inside.
I got home- changed the oil and filter, flushed and added new coolant. No radiator leaks. Seems like the water pump is working- I had the radiator cap open, with the car running, and it seemed like coolant was moving. But maybe its going bad?
1. The car only starts to overheat when its NOT moving. When it just sits in park/stopped, eventually the tach starts to climb. When the car is moving, the tach stays in the middle, but SOMETIMES it was climb just a LITTLE, about halfway- maybe a pinch above that.
2. The blower is working, but 90 degrees is more like 65-70.
3. SEL is on because of P0507. I'll have to perform the Idle Air relearning.
I'm thinking maybe I have a T-stat thats on its way out? Bad cooling fan? Waterpump? Heater Core? Any advice would be great.
Thanks ,
Vannak
