No heat?? help!!
redline240sx
Car: 1991 240sx
Ok, well after a year my heat stop blowing in the car...
After reading on how to pull and replace the heater core from thris thread i am wondering what went wrong with my heat?
It just stop like that, maybe a fuse? resistor went bad? i try putting it on , but i am not getting anything, why?
Any advice will be appreciated, thanks......
rioredstang
Car: 1993 240sx SCCA ITS
You need to unplug the blower motor. Turn ign. on and turn blower on. Take a test light and check for power on the connector. If no power is found then check fuses.If you have power then hook the test light power source and check for ground at blower connector. If you don't have ground then you may have a bad blower motor resister. If you have power and ground then the motor has gone bad.
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
Does it blow cold... or does it not blow at all?
If it blows cold = Thermostat.. get OEM replacement.
If not blowing at all = either the relay, or the climate control unit.. or both..
redline240sx
Car: 1991 240sx
It doesnt blow at all, when it did work last year it blew really hot, then this year i dont know.
Is there a short cut where i can access the resistor and the motor by not taking the dash board out? maybe throught the glove box??
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
The blower motor and resistor can be accessed by removing the glovebox door. The resistor is just to the left of the blower motor.
redline240sx
Car: 1991 240sx
sx moneypit wrote:The blower motor and resistor can be accessed by removing the glovebox door. The resistor is just to the left of the blower motor.
Thanks, i think i have enough information i need to get started and to see where it lead me, thanks.
sx moneypit
1986 Toyota MR2
Glad to help!
