no heat, freezing to death
driftingsyn
Car: Nissan 240sx
i have no choice but to drive my car this winter, and the heat stopped blowing out. heat flows out but the fan stopped blowing. i was told its probably either the blower motor, or the fuse but i cant find the fuse, anyone know where it is? and if not how much of a pain is it to replace the motor?
theother1wstolen
Car: 92 240sx Coupe SE
um... did you check the fuse panel?
del82
theother1wstolen wrote:um... did you check the fuse panel?
Ouch
Additionally, it could be the resistor block that controls the fan speeds, but generally if that fails you'll still have the highest setting on the blower. But yes, it will have a fuse in the fuse panel, and the panel or the panel cover should be labeled, if not check your owners manual. If you don't have that, grab a Hayne's/Chilton's manual for your car at the parts store, it should have the diagram as well.
theother1wstolen
make sure to check both fuses when you check the blower fuses btw.
driftingsyn
Car: Nissan 240sx
the lights for the defrost and everything still turn on, but i dont get any speeds. when im driving, and i slow down i can hear something that sounds likes its coming from the vents as if theres metal or something moving around in there...it didnt start till my heat started messing up, which somedays it would work and others not, untill it just stopped all together, after that the sond has gotten louder
theother1wstolen
ive never had a blower motor go out on me, but if i had to guess thats what it sounds like to me, anyone else have more info on it?
2projects2many
Car: '91 S13 SR20DET
May check your control panel- I know mine stopped working on high, and that is what it was.
driftingsyn
Car: Nissan 240sx
sooo.....i found out what it was. one of the fuses melted that goes to the blower. now i just have to find out where the wire leads
Rin5
Car: 1990 240sx CA18DET, 1990 240sx SE fully auto (Daily)
please refer to:
lol jk but yeah you shouldnt need to be tracing wires if your fuse blew...check the covers...if not theres plenty of stickies around here....unfortunately for me...i havent had time to work on mine but its just a simple reinstall...i took it out to mess with ecu wiring...cold as balls i tripple up on layers and double gloves (1 hour commute to work lol)
