No heat blow cold air
j3095
do you guys have a problem with the heater won't blow hot air if the temperature at your climate control less than 85 degress, and if you drive on the freeway more than 30 minutes all sudden just blow cold air until you turn down the temp, and turn all the way up again .... any suggestion will help, thks
Rex
Car: None
See if any of this applies
zerothread?id=143185
zerothread?id=4137
Chezedik
Car: 1991 Nissan 240sx
Rex is very good, and I never mean to blast... But have you thought about bleeding the coolant?
