no heat at idle
otgarza
Working on a 05 M35 and it blows cold air at idle, as soon as you drive the heat kicks in. Once you come back to a stop it comes out cold again. What are a few things to look at?
svard75
Car: 06 M35x
Search man!!! It's likely air in the heater core. Burp the coolant until it starts to work again.
otgarza
Did a google search but no one ever says what worked and what didnt. How is this system burped...thru the radiator or does it have a bleeder
svard75
Car: 06 M35x
Fill rad when cool, run car with heat on max till NOT then let cool refill rad, repeat till rad level max and overflow bottle is at full hot line.
jiggersplat
Car: 2008 Infiniti M45x
1995 Toyota Supra TT 6-spd
I ended up having to have my heater core flushed.
svard75
Car: 06 M35x
That's pretty extreme. How did they do that?
jiggersplat
Dunno. All I can tell you is they bled it before I took home the first time after the radiator swap. I bled it. They bled it again and it still wasn't right. What I can tell you is that the customer waiting area had a Keurig machine and cookies ;)
In retrospect, the time the radiator blew was the first time I think I had the heat on this season. I wonder if a clogged heater core was causing extra pressure in the system which caused the radiator failure.
svard75
Car: 06 M35x
Could be continual use of tap water that led to corrosion and calcium buildup. Why did the rad blow? Or was it pipes that blew?
jiggersplat
It was the bottom seam where the plastic is joined to the metal.
EdBwoy
jiggersplat wrote:It was the bottom seam where the plastic is joined to the metal.
Typical Nissan radiator problems :biggrin:
EdBwoy
otgarza wrote:Working on a 05 M35 and it blows cold air at idle, as soon as you drive the heat kicks in. Once you come back to a stop it comes out cold again. What are a few things to look at?
I'd also say look for coolant leaks around the rad hoses and under the car. But if you recently did some coolant service, definitely burp it as said above first.
Findmorefire
Car: Infinity m35
2007
I had a problem similar to your and I searched and search for a answer even from technicians that I trusted . Turns out I had to replace A/c relay on my M35 that was located behind fuse box.
Test relay or just replace if not to costly.
Findmorefire
Car: Infinity m35
2007
Disregard my last message . I just realized you have a heat problem . I had a a/c problem . Good luck trouble shooting.
Ilya
You bumped a 2yr old thread...pretty sure there is no troubleshooting being done.
Welcome to the forum regardless :).
