well woke this morning to 10 degrees outside. Started M35, let warm up for 25 minutes, got in her nothing no heat. Everything was on temp set at 75, on defrost. Drove 12 miles and then she finally turned on high with hot heat.
I have had car with a bad thermostat and they would get warm while sitting there not moving but as soon as you would start drivng the engine would loose heat and start blowing cold air.
Granted this was on a 87 prelude many years ago with no climate controll or air sensor.
Am I missing something here. is it kind of back wards that the engine is not gettting hot enough because the t stat is stuck open so the air temp sensor will not get hot enought to blow hot air untill it gets really warm.
I will change the t stat and see if that resolves the problem.
Anyone done on a M before? I have not even looked to see where it is yet.
Any help would be great...
Miles
