centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Mon Oct 10, 2016 4:51 pm
Well, when I redid my coolant system, including heater core stuff, I hosed out my heater core. Basically I unplugged the two hoses at the firewall and connected one to my garden hose. It blew some odd looking chunks out of there.
While putting it all back together, I filled in coolant/ water wherever I could (not just into the radiator), then connected the pipes. After all of that, I went ahead and bled the air out of the system. My bleeder is sheered off, so I had to do it on a slope and burp it through the radiator.
For you, I recommend flushing out the core. This will verify that you have flow through there anyway. Then I recommend bleeding out the air.
Your vacuum lines are a separate issue. I'd look to the FSM for both engines and see what they were supposed to do. I think you could put in a wye (Y) or tee (T) and run two hoses to one as needed.
