No glow behind gauges
silverQ
Car: 1991 Q45 180,000 mi
98% of the time the gauge cluster glow doesn't work (the grey glow that encompases the whole gauge area). Anyone have any ideas as i've never tore down that area before and am hoping it is a simple wiring problem I can attack from the bottom or something. l8r
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
have you looked at the wiring diagram in the FSM?
silverQ
elwesso wrote:have you looked at the wiring diagram in the FSM?
sadly im on dialup aka turtle speed
Do you have friends?
Raxephon
Car: '04 RX8...for the moment...
Illumination diagram
I'll post up the cluster diagram if you need it as well.
Q451990
There is a layer that sandwhiches behind the bezel that goes around the gauges and plugs into the cluster. It's a small two pin connector if I remember right. I think it's sort of like an indiglo watch dial face. In any case it plugs into something on the cluster, so the wiring diagram won't help you. Mine failed on Q1... never got around to replacing it.
I think you can buy the part from Joe... or it might be cheaper to buy a spare cluster on eBay or from one of our parts cars on NICO. I'm not sure that all years had it... (maybe a 90-93 thing?) so I would confirm that before buying a used part.
Good luck!
Heath
